Download and Installation Instructions
Step 2 Install the software
  1. Locate the downloaded file in the Finder. The disk image will look similar to the icon below. Double-click it to begin:
  2. The window below should appear. When it does, double-click to launch the installer:
  3. On the installer's first screen, click Continue:
  4. First it will ask you to agree to the license terms. Then click Continue:
  5. When this screen appears, click Agree:
  6. Select where to save the software on your computer, and click Continue:
  7. When this screen appears, click Install:
  8. Installation will begin and a you will see status messages updating:
  9. When the install process is complete you will see the message below. You can click Close:
    Next, your account and device set-up process should start automatically in a separate screen. If you don't see a new screen, locate the Fitbit application on your computer and double-click it to start.
